- Oct 11, 2021
- 74
Ok...I have a 73 Bronco with a 67 body and dash. Once in a while I had turn signals and brake lights. Now I have neither.
I Replaced the turn signal fuse nothing.
No fuse for the hazards, so I got one and it doesn't fit correctly. I was able to get it to connect to the fuse. The fuse clicks even if the hazards are off. With the hazards on the rear and front lights light up. When the hazards are on I can press the brakes they still flash.
With the key on and the flasher still on I can turn the right signal on and the left will flash. Turn the left on and the right will flash. Still no brake lights.
I'm at a loss. I have the body grounded to the battery, ground coming off the gauge cluster to where the emergency brake bolts to the dash. The wiring is somewhat of a mess because it has the 73 wiring from what I can tell maybe ?
