- Mar 8, 2007
- 81,779
Maybe a good score for someone
couple different ones for sale
1966 Early Bronco U13 - $6700 (Olathe, KS)
https://kansascity.craigslist.org/cto/4744312304.html
For sale is a solid 1966 U13FL I purchased earlier this year. Being an original roadster, the top and doors are from a later model Bronco. It needs paint but has a good tub. The engine is a 1974 302, I have recently installed an Edelbrock 600 cfm 4-barrel carb, fuel filter and mechanical fuel pump. Have taken many trips around the neighborhood, but the timing still needs adjusted. The C4 automatic transmission was recently rebuilt when I bought it, and has a B&M floor shifter. Transfer case and AT are in good working order. The frame is rust free and entire belly is really clean-rust wise, the floor pans still retain the factory Red Oxide primer, but there is dirt and road grime obviously. The rear bed area is rust free and nice. The lift seems to be s 3.5" suspension lift and a 3" body lift. Tires are new 35" buckshots. Door strikers and posts are clean and could use adjusting as the strikers were added (68-77). Passenger side door glass needs to be put in, I have the glass just haven't put it in. The front seats are aftermarket, but I do have a pair of white OEM front seats that need recovering and a tan rear seat. I have been tinkering with this Bronco, but just don't have the time to do what I want with it so I figure it needs to go to someone that does have the time. Have title in hand and ready to sell - $6,7.00 obo
