    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
AR OCBR 2017 For Sale-Wanted Thread
Status
Not open for further replies.
fordguy
Neutral Safety Switch for C4, plugs have been cut off but in working condition, just have to splice it in or add plugs back to it. Recently pulled off my 73. $30
Shift rod, goes from the column to the transmission - $25
Shift lever that connects to the transmission - $15
Can add pics when I get a chance.
might need those shift rods, will let you know tonight
fordguy
Four 31x10.50x15 Yokohama Geolandar AT-S tires mounted and balanced on ford steel wheels from a 95 F-150. Wheels are not pretty but tires only have around 1500 miles. Asking $400
Fiberglass half cab. Painted white. The inside is painted black with a textured paint or some type linear. There is one small nick on the side that was painted over but the top is n very good condition. Don't know the brand but seems to be well made. No bulk head, Asking $600
Will email or text pictures if interested.
what is the bolt pattern on the wheels?
JSBX
Hey Billy. They are 5x5.5. I took those off the 95 F-150 and put some off a Bronco on the truck. Wheels are ugly though. Will text you some pictures. If I can find your number.
James.
NYLES
I still have this set of one tons off of a 95 F350. They have been shaved and are ready to be linked. Dana 60 front and Sterling 10.25 rear. $850.
Would you split em? Im not real fond of the sterling.
jrcflash
1975 Bronco project 1.5 hours west of Hot Springs Arkansas
I started with a perfect bare frame and assembled it with a WH system 16 2.5 inch lift with F250 front towers and inboard rear shocks. Rear end rebuilt with 4.56 gears, Eaton Tru-Trac and WH 31 spline axles. WH extreme U-bolt kit. Front is disc brake 76 Dana 44, gears are still 3.50. I have a new 4.56 Richmond gear set and master install kit but have not purchased a carrier/locker. Front end has a 1 Ton TRE DOM set up from ExtremeCustomFab. I have six hard to find 15x8 slots with the proper offset to run with the factory 76 Dana 44 knuckles tie rod under. Chassis is assembled and rolling still needs brake and fuel lines installed.
Engine and transmission are in the frame. 1996 Explorer 5.0 with GT40 heads (not P). Fresh valve job, new timing set, water pump, and factory aluminum two barrel intake (84 Mustang GT). ZF S-542 trans. Have not purchased the ZF to Dana 20 adapter.
Other good hard parts include J-shift Dana 20 with T-shift gear set, WH Rock Jox, 6-turn power steering box, Hydro-Boost set up from 2000 Mustang, Braided chassis and caliper brake lines, Carter electric fuel pump, BC braided clutch master cylinder line, refurbished gauge cluster, Alternator harness, Headlight harness and lots more I can't think of right now.
Body is sitting on a separate frame as can be seen in the pictures. Floors, Door Post, and rockers need to be installed. I have some but not all of the metal that needs to be replaced. All metal above the floor in the body is very good. I have good doors and tailgate and a hood that is fair.
I have done lots of work and of course a lot more will need to be done to complete this project. It will be a very good one when complete. I would like to see this go to a good home a be completed. $8,500. If seriously interested, give me a call 479-234-8382.
Skiddy
I also have a brand new pair of 2 1/2" lift Cage shocks
kshinnall
Newbie
List of parts I'm looking to sell. Also, only bringing what sells instead of hauling all this to Hot Springs.
Set of new rear 6 pack leaf springs (5 pack with add-a-leaf) with bushing and new U bolts $225
C bushings with radius arm bushings $25
Stock tracking bar with new bushings $20
Set of 4 Cragar "Soft 8 Silver" steel wheels 15x7x5.5 w/4" back spacing with bolt in valve stems and set of chrome lug nuts(less then 500 miles) $150
Set of 4 Daytona tires 235/75/15 lots of tread left. Recommend these for trail use of farm use only. $100 (not mounted)
New Rampage tube bumper, no hoop, for 87-06 Wrangler (will fit 66-77 Bronco slight modification) painted silver $120
2 old school halogen KC lights $50
OEM air cleaner for 302 73-77 $40
Usable stock bumper $25
Stock rear driveshaft, was used till I added lift $40
1" lift blocks $15
2" lift blocks $20
I can send pictures of items. Just send me a PM and I'll text them. Just give me some time since I don't have pictures of all the items on my phone, yet.....
:)Thanks and looking forward to seeing all the old Broncos!!:)
okie4570
NW OK
Looking for.........
- stock bucket seats, 66' would be an ultra bonus :)
- 66' seat belts
- lt235-85-16 A/T or MT, used
Selling........
I'll start digging thru and post up some pics and prices.
JWMcCrary
JWMcCrary
I'm about to pull a stock rear fuel tank that should be good. Been sitting for about 5 years inside my shop but we put gas in it and drive it around for a while before it was parked and makeover started.
JWMcCrary
JWMcCrary
I'm in need of front seats, need to be black and in decent enough shape to bolt in. Not interested in stock seats.
stout22
Athens, AL
What degree are the C bushings?
okie4570
NW OK
I'm good on the fuel tank JW thanks, found one local.
JWMcCrary
JWMcCrary
I have a Tuffy 8" console with a Pioneer Bluetooth radio already installed. The radio is about 2 years old. Pioneer Model DEH-X6600BT, remote an operators manual included. The console is missing the cushion from the top cover and the strap off each side. I robbed the missing pieces to use on a custom console. Only reason selling is due to changing to a floor shifter. Tuffy drink holder mounted on front seen in pics is included. Comes with 2 keys. There are 3 spacers needed to clear the stock seat belts when mounting, they are included. There are two 1/8 inch holes on the drivers side near the top where I had something mounted, other than that excellent condition but could use a good cleaning. The 2 white strips you see in the pic is what is left of some double sided tape, I peeled at it with my finger and it should be easy to get off.
$125 delivered to OCBR
*****No longer for sale*******
BIGED
Guru ????
Haven't seen anything new added I better go check my pile of parts
okie4570
NW OK
- 66' seat belts
Selling........
Bump and add some things for sale.
-5 newer style wheels with 235/15 tires. Unknown age on the tires, one looks like it's never been on the ground, others are worn. I do have the center caps and beauty rings. $100
-Mirrors, no bolts or gaskets. $20
-2 15" wheels, unsure on width, will probably have two more by OCBR, and
two wagon spoke wheel. Tires not that great. $30 for the pair
-Edelbrock 650. Been sitting on the shelf for a few years, ran fine when I
took it off, could use a bath. If was setup on a 302 at 8500' of elevation but
ran fine here at 1200'. $75
-66' tailgate, rough condition, has all hard ware/handle, etc. PO from years
ago tack welded a wrap around piece of sheet metal around the lower
portions, assuming it's rusted out under there. Still solid and functional, but
obviously rusted. No license plate bracket or light. $50
-Stock rear fuel tank, outside okay, inside rusty, it sit untouched on the
bronco for 30 years with some gas in it. $30
-Black bikini top, unsure of the brand, no bracket, just the skin. Good
condition. Whatever brand that has the two pieced arched windshield
bracket, that's what this one fits. $50
Status
