mavman427
How's it going everybody, thought I would use my first post to start a build thread. About a year ago, I bought a 1971 Bronco to begin playing around with. As it always seems to turn out, it ended up needing a lot more work than I initially thought. Anyway, here are some specs and pictures of it:
1971 Ford Bronco
302 2V
3 on the Tree (converted to 3 on the floor by a previous owner)
3:54:1 Dana 44 Trac-Lok. front axle
3:50:1 9" ford rear end (large bearing)
4-wheel manual drum brakes (brutal!)
Manual steering
Koenig PTO Winch/Front Bumper
There is some rust on the hard top rain gutters, on the inner fender apron, and in the floors. A previous owner took the liberty of welding some plate on top of the rusty floors.
The goal of this build will be to get a decent looking street/trail rig that is dependable and can perform on and off the trail. It won't be a show truck or a rock crawler, more like a driver with good offroad capabilities.
Here's what I eventually want to do to this Bronco:
-Custom PTO winch/front bumper
-Ebay heavy duty rear bumper
-Power steering (from 75-76 Bronco)
-Front disc brakes (from 75-76 Bronco)
-Tom's Bronco Parts Brake Booster and Master Cylinder
-Rear ARB air locker
-3.5" Lift Wildhorses Leaf Springs
-3.5" Lift Wildhorses Rock Crawler Coil Springs
-1" body lift
-Rear "helper" airbags
-315/75/R16 Firestone Destination M/T's
-Warflares
-Custom shocks (need to run some Matlab simulations on this and optimize the shocks)
-4R70W automatic transmission
-Extreme gearing/output shaft for Dana 20 transfer case
-Custom hand-built wiring harness
-HID Xenon Front Lighting
Without further ado, here are some pictures of the Bronco in the condition I received it.
1971 Ford Bronco
302 2V
Manual steering
-1" body lift
-Warflares
