So my Bronco had been sitting since some time in the early 2000s . Got the wiring harness changed and updated and got it running again. So I've probably put maybe a couple hundred miles on it now. So I've noticed now once I'm done on the drive it leaks grease from the trans out the side behind the shifter levers? Is this a easy repair one can do with the trans in or will it need to be removed to fix ? Any help is always needed and welcome! Thanks guys!
