mango
Finally got a chance to start digging into a soft pedal issue today, and discovered some ugliness.
Cleaning the mud off of my new front discs, (conversion kit), I found that my brake pads were severely worn.
Caliper bolts were rusty, as were most of the parts. I also removed quite a bit of packed mud. I thought that this might have caused the calipers to stick, prematurely wearing the pads.
Checked the rears and found the new shoes were also very worn. All were worn to the point of needing replacement. All were equally worn.
My brakes are all new with less than 900 miles on them. Manual brakes. No power assist.
New front disc conversion kit. Knuckles are ground for clearance. All new s.s brake lines. New MC. It is the F-250 camper special. I am on my second proportioning valve. The revolver shaped one. The first one leaked where it shouldn't.
I checked the push rod. It has play and is not constantly pushing at the pedal.
The MC reservoir for the front was very low. That could have been my pedal needing pumping. The rear was barely down at all.
Could this be my MC, or the proportioning valve. Safety first. My family is sad that the truck is down. We will do whatever it takes to get her back up and running....So I can go after some of the other issues.
Thanks.
Mango
Thanks.
Mango
