Pebbles: 1 Family Mostly Stock 68 Build
sprdv1
REBEL
After taking the winter off, I have fired up the compressor and blaster. Working to get all the parts clean and rust free so I can bring them all to the zinc plating place.
Busy man... I don't blame ya for taking a reprieve during the winter.. So hard to get motivated when it's cold out..
Keep up the good work
Crawdad
I’d remove the transfer case cross member and it’s brackets if and when u have it dipped or coated. You will be mad at ur self later down the road.
Keep it up!
Matt
chuckyb
chuckyb
Frame repairs complete and thanks to migs!
Frame repairs are now complete. Front and rear body mount areas have been repaired using the pieces provided by classicbronco member migs - highly recommended!
Both rear upper shock mounts replaced with pieces from Bronco Graveyard. The frame has been de-burred to clean it up from how it left the factory (50 years ago last week).
All measurements have been taken to verify that the chassis is straight and will line up correctly with the body. As we thought since there is no family knowledge of any wrecks, it is all straight.
It is now back with the blaster, waiting in line for powder coat in chassis black.
chuckyb
chuckyb
Floors in, more fitment, welding underway
Some updates from the body shop today, it is really taking shape. No more Flintstone Floorboards :)
chuckyb
chuckyb
Zinc plating
I’ve had pieces of my Bronco scattered across five shops in four counties. The most pieces were at the electroplating place and I brought them home yesterday. I’ve got some sorting to do. These are before and after pictures. I am happy with the results!
chuckyb
chuckyb
Welded and Epoxy sealer
The welding is complete on the tub and it is now sealed. It is nice to see the 73 windshield on for the first time. 289, 3 speed and Dana 20 are in the queue at the machine shop.
rydog1130
looks good! just a matter of time before its back on the road! what was the reason for a 73 windshield!
chuckyb
chuckyb
Thank you, Ryan! I’m looking forward to bringing another 68 back to life. I had access to a 73 parts rig years ago and got bucket seats and a nice windshield and wiper set-up among other things. I had considered re-using the original windshield and vac wipers for originability and character but ultimately decided to “modernize” on this aspect of the build. The 68 windshield and bench seat are resting in the rafters of my shop for now.
rydog1130
gotchya! cool man!
CLT_NC_Mitchell
Mooresville, NC
I had announced these as on their way for a chemical dip but instead they were cooked in an oven.
Nice thread, can I ask what made you go the bake route vs a chemical dip? Did media blast before baking as well? I’m also in Mooresville so when it comes time to get the body on the frame, I can help if you need another pair of hands.
chuckyb
chuckyb
Thank you! Good to find someone in Mooresville, and I am happy to lend a hand also. The baking was a bit easier on the budget for my tub and also included blasting. With all the sealing that is being done with the body work, I feel I will be getting the same result. While the tub got baked, the frame got dipped.
CLT_NC_Mitchell
Mooresville, NC
The baking was a bit easier on the budget...
I hear that, Cash is King. I’m sure it was fun and frustrating at the same time to sub-contract your build. I’m still in the exploratory phase with mine but when I get to stage I’d like peak at your vendor list. I figured I’d start with the vendors that NicksTrix uses if they can work in small jobs like mine would be. I subscribed to your thread to watch your progress. See you around Chuck!
JGbronc
Bronco Maniac
I'm loving this build! The fact that it was your Grandfather's makes it even cooler. Keep up the good work!
chuckyb
chuckyb
Thanks guys! An update on recent progress, I am focusing on being ready to start the build as I am expecting to bring my powder coated frame home soon. I need to have a rolling chassis ASAP to keep the body work on track. The axle housings have been POR-15’d with chassis black along with new coil cups etc. The rear axles have new bearings installed and the front axles have new u-joints installed. Driveshafts are being rebuilt and balanced. Rear driveshaft is being shortened 9” to accommodate a Rancho Borg Warner overdrive. Weather permitting, will work to get POR-15 silver on the radius arms and bell housing this weekend. Dana 30 rebuild kit and front disc conversion kit are in boxes and ready to go.
sprdv1
REBEL
I'm sure you can't wait man.. Good luck
chuckyb
chuckyb
Frame is home, the build begins
The powder coating is now complete. I am happy with the result. My son and daughter each helped me install a shackle to kick off the build. Next up is to install leaf springs and rear axle housing, then move to the front and get the radius arms and D30 attached.
chuckyb
chuckyb
Tub is primed...
...and ready for sanding and paint next week.
