- Nov 3, 2003
- 47,639
The early systems used .035. I think you’d be safe with .040 to .045 in yours.
I believe I use .042 in mine. But if it can support .044, a little wider is usually considered a little better as long as it doesn’t misfire.
Whether you keep your system or not, comes back to the early statements about checking the condition.
There are bushings that the shaft spins in, and they do wear out. However, as often as I’ve seen the old points distributors worn out to the point of being beyond use, I have literally never personally experienced a worn out Dura Spark distributor.
Still happens though, so still check a few things out.
