Pitman arm sector shaft over-engagment
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Stock Ford power steering box (72) & power steering piman arm.
Pitman arm is so far on sector shaft that the nut and lock washer bottom out on sector shaft.
PO used a ball bearing race as a spacer (not a good idea).
Is this typical, am I missing a part, or is there some other issue I need to discover?
Yeller
Rogers County Oklahoma
It probably got ran loose at some point. I have one that has a flat washer on it along with the lock washer, was a roadside repair that has been running strong for the last 10 years…. I really should fix that I guess.
What is the overall condition of both sets of spines otherwise?
Oldtimer
Oldtimer
Sunnyvale, CA
Straight Line Steering told me the pitman arm is worn out, most likely from driving with loose retaining nut. I have a different arm that sits flush when installed, so sector shaft may be slightly worn. Manual pitman arms have a smaller diameter splined hole so they go on with plenty of engagement.
POWER STEERING PITMAN ARM
MANUAL STEERING PITMAN ARM
Edit: added photos
Man, that thing is so far down the hole, it looks upside down! :) It’s been so long since I had my original one off, I don’t remember how much, if any recess there was.
I had an aftermarket arm that must’ve been breached incorrectly. Or had some burgers on the spine that I didn’t detect
I tightened down the nut and then once or twice a week I would re-tighten it. I had to re-tighten it for six months of daily driving before it finally seated fully on the taper.
jamesroney
Fremont, CA
You are reminding me of why I often end up using the manual arms.
I have had to machine a step collar for these in the past. It only needs to be about 1/4 inch thick. I suppose you could make a fancy nut as well, but I like the big split lock washer.
Make certain that the major OD on that forging will fit your puller. I usually put a couple of flats on the 78-79 arms so that the average cheap pitman arm puller will fit. I don't know why Ford made that part so big.
