Abe Jauregui
Newbie
This forum has helped me out so much. I've read every post about tuning and possible misfires and still can't get rid of this popping sound from the front passenger side of the exhaust. Here's what I have rebuilt stock 302 with the big spark plugs (only mention this because when I bought spark plugs for a 1970 ford bronco they gave me smaller ones.) I have a holley 600cfm electric choke with this Ready to run distributor. It's a 3 speed column shift. I have checked the firing order (1,5,4,2,6,3,7,8) and the wires are all new and good. Checked them with a timing light. The choke is not sticking and neither is the fast idle speed screw. I have triple checked the idle mixture screws moving them 1/8 of turn using a vacuum gauge connected to full manifold vacuum. The cars runs great and starts up fine, its just under load and shifting 3k and later does it backfire/pop. For timing, I have tried stock 6-8 degrees, advanced it all the way until 16-18 and nothing changes. I have hooked the distributor to timed vacuum on the carb and then switch to full vacuum and nothing cures it. Spark plugs are nice and tight. The curb idle screw isnt even engaged because when its armed up it sits around 750-850 without it. I have checked for a vacuum leak using the carb cleaner method and the idle does not fluctuate. Could it be the regular gas I am using? Should I use premium? I have noticed that it does burn through gas pretty fast. fuel pump is new. Any help would be appreciated. Like I said, it runs like a champ I just don;t like the popping sound going into second and third gear.
