Well this past weekend I had a chance to get my bed section welded in, took a little bit of time - maybe 2 hours for fit/tack/fit/trim/tack the other night, then went to town yesterday seam welding it all in. I was going to spot weld it in but it just seamed sooooo much easier to seam it in and I wont have to worry about the stupid seam sealer. After I clean up all the booger welds (there are quite a few) it should look real good. The fit was pretty damn nice, JBG extensions and fillers, Tom's bed and wells (I think theat everyone sells the same but JBG is the only place to get the extentions and fillers. Very little trimming necessary, fit nicely. Here is my process...
First I put body mount bolts in and tacked the rear support panel to the frame (keep anything from shifting around)
Everything was all wirewheeled and flapdisc'd (inner fenders, front floor where it meets, rear support, along with everywhere the sheetmetal would meet up)
I sprayed weld thru primer over all these areas (mistake...the stuff sucked and just made for ugly welds - wouldnt do it again - ended up wire wheeling it off everywhere I could)
Decided to do the passenger side first since it didnt have the filler panels.
Clamped in the front and rear extention panels, tacked them in cause I was out of clamps
Slipped the wheel well in to check fitment...
Adjusted a little, made sure the line where the bed went in was flush
Tacked the extensions in again, while a friend was holding the wheel well in place tacked it to the inner fender and the extension panels.
Did the driver side extensions and wheel well - tacked them in
Then fit the filler panels -
Front one took a few hammer blows and shaping - not much - just to make it able to clamp
Rear one was a PITA because of the angle, a number of hammer blows and some sheetmetal screws to sinch it all together, tacked in place.
Again checked the lines to make sure they were clean
Brought the bed section over and slipped it in....fit was perfect - only had to grind off the vertical side where the panel fit over the rear support to make it flush - about an inch, nice!!!!
Clamped it to the extensions - front, sheetmetal screws from on top through the front floor to suck it all together - spot welded
Checked level, tacked the middle of the bed and the rear. The rear cutouts for the body mounts were a little wierd, the driver side was right on, the pass side was off (side to side) by about 1/2 inch - just cut wrong by the factory.
Checked all my gaps, clamped as needed and went to town.
It looks Awesome and was pretty damn easy!!!!
