PS fluid or transmission fluid?
my PS pump on my '69 on the dip stick says to use automatic transmission fluid? was just checking to see if this is indeed a good idea or if i should be using regular PS fluid, which i was also using regular PS fluid on my automatic '71 which i just assumed was what i needed to use, however the PO had a bottle of tranny fluid under the hood which i can only assume he was using in the PS pump.
which ATF should i use?
