mountaineer block with a half thousandth wear in the cylinders, with custom roller cam (idle to 4500) heads have blended bowl work, extensive exhaust porting, 1.9 and 1.6 valves and roller rockers. short block has just been built with honed cylinders, new rings, inserts, cam bearings, etc. performer rpm intake with gasket matched porting. dizzy with steel gear and petronix ignition. crank was polished. crank, rods and pistons were also balanced, comes with matching flywheel and harmonic balancer. did not put the heads on it in case someone wanted to inspect. not sure if machine shop has put the oil pan on either. plus shipping. pretty sure the machine shop will crate and ship. comes with a six month warranty if bought locally. comes with head gaskets and will cost more to put the heads on. do the math, not a bad deal. I have another engine I will be running in my bronco so this one needs to go. ship on your dime.
