Hal9000
Last night I started looking at how to cut off the stock radius arm mounts so I can install my extended radius arms. Actually I started grinding on the welds on the driver side....
Access seems to be a huge problem here. The brackets are welded inside and out, and across the bottom of the frame. That's in addition to being bolted inside and out and the bolts welded in place. Ford REALLY didn't want these brackets moving! Getting the grinder in to cut all the welds is proving to be more than a little difficult. I'd like to re-use the brackets if I can, so I don't want to just chop them off, and I don't want to damage the frame obviously... I wanted to find out how those of you who have successfully removed the brackets have done it.
