vtboy51
- Aug 26, 2016
- 389
I'm fitting my cage to be welded and I realize because the PO welded in some "overlay" floor pans my floor heights are a bit higher than normal. This is a Bronco Bob cage, that has been tacked and fit to a normal bronco, so the front section sits a bit taller because of the shitty floors. I've got two concerns, first the front section sits higher and may cause problems if I put my hard top back on (and it just looks unlevel). Second, if I ever correctly replace the floor pans the cage will not fit properly, it will be angled a bit to high.
I'm trying to determine the best way to solve this, I was thinking of cutting the section of floor directly under the cage foot pad and recessing it down to the original floor, thoughts?? Or maybe I had add an extra 1/4", or so, plate under the mid and rear feet to level it out, then just remove the shims once I replace the floors.... Any advice is greatly appreciated.
