- Aug 27, 2001
- 5,147
The '68 all stock seems to run much better for some reason with the vacuum wiper hose off of vacuum porton on the manifold behind the carb. When wiper vacuum line is hooked up...you can rev it up with a quick sharp thrust of the throttle arm and it has a slight hesitation. You can unhook the vacuum line from the port (motor idles higher when unhooked) and leave it open to suck air and it will rev instantly when the throttle is moved sharply. Much more responsive with it drawing outside air. Usually on all the other Broncos....I can unhook a vacuum line and it runs like crap till I hook it ack up? Any suggestions? Thanks Much,
Blue71
Blue71
