- Oct 4, 2015
- 340
I lifted my 74 Bronco with a 3 1/2" lift kit from WH. I also have a 1" body lift. I added the dropped pitman arm and trac bar bracket. The tie rods and drag link are new. My C bushings are 7 degree. I have had the front end aligned and my caster angle is about 3 1/2 degrees. The toe-in is set at 3/8". I have had the steering box rebuilt at West Texas Off Road. I have looked at the front end with a helper turning the steering wheel and see nothing moving that shouldn' t be moving. Yet when I drive, especially when I put in the clutch, the front end wants to wander. I talked to Wild Horses yesterday and 2 things were suggested. Either I could go with Bilstein shocks, or add front stabilizer bars. The shocks are the least expensive way to go. So, I'm wondering if any of you guys have had this problem and added the Bilstein shocks and if it made the problem better. I would like some input before I spend the money. Thanks
