MI-Bronco
- Jan 4, 2002
- 941
ok - I should have but didn't chang my wiring yet. However, I did put in a new light switch. Since then (really don't know if it's related) - I've had all sorts of electrical problems. Lights work, but cluster light flickers - turn signal indicator lights go on when I hit the brakes. Turn signal goes on (right side) if I plug in the flasher. Tonight, I'm driving home with the lights on and smoke starts coming out of the dash.
Turns out one of the brown wires attached to the light switch melted (285 on wiring diagram), and caused colateral damage to other wires.
Now, before you tell me it's the ground - I agree!! What seems funny is I just sanded down the grounding strap on the rear drivers side light. And guess where Mr. Brown 285 goes to? Right, the driver rear light.
So, I guess it's time for new wiring - and I'm making sure it is grounded even if I have to drive around with a 4' ground rod dragging behind me!!!
