SpareParts Build Thread...Linked and tons!
SpareParts
SpareParts
Dale, we've met, I rode with you a short time at 06' OCBR and our pictures is in the BD article for it. All I did last year was ride with people and take pics., almost all of the pics that were printed was from me.
No time won't let me have it painted, it maybe in primer when I come down there. Trying to get the essentials done first, I'm starting on the family cage tomorrow and trying to finish the bumpers and triple sticks today "LABOR DAY WEEKEND". I'm doing almost everything myself, with the help of a couple of friends, including the body work and paint, in not going to make it perfect but I do want it nice.
Heres a pic of my last ground up, 1980 F-350 cab, 1996 clip, doors and bed. It has 9" susp. and 3" body lift. We made all of the drop brackets and tranny crossmember, front receiver for winch and license plate. It started out with the small block that is in my EB, but when I started building the EB I pulled it out and installed a 460 BB and C6. I built it abour 6 years ago and painted it about 5 years ago. When I put the BB in it I also swapped out to 3/4 ton axles.
I better get outside and get some work done.
David
SpareParts
SpareParts
I didn't get time yesterday to post the progress, I got too tied up working.
Here's some pics of the bumpers, they are a work in progress. Removable receiver mount for the winch on the front.
Cage is getting mocked up, it is the Trailworks kit. The rear supports "down bars" are cut wrong, they fish mouthed the wrong ends. If I have time I'll fix it, if not I'll call them on Tues. and see what they will do.
Triple sticks work, I don't like how far the throw is on the 203. So I might modify it again, LOL.
Rear brakes are installed, weld on calipers, 73 Impala Calipers, lines and shoes, 83 F-150 rotors with the axles turned down to clear inside of rotor. I still have to get the right studs, these are just mocked up right know.
I'll get some better pics of the triple sticks and brakes when I get it back on the lift.
Got to get back to work.
David
SpareParts
SpareParts
Heres some better pics of the bumpers and the under seat storage. I still have to round the corners of the shackle mounts and do some bracing to the front.
David
SpareParts
SpareParts
Working on the torque arm and playing with the rear end flex.
bowhunter
Spareparts - It looks like you're gonna have to burn some serious midnight oil to make it OCBR!?!
You coming this year?
Dale
SpareParts
SpareParts
It won't be painted, but I'm going.
I do have a couple of things to do!
David
SpareParts
SpareParts
I have been working on it for what it seems nonstop for the last couple of months. I have had alot of help from friends, even if it is just to hold something in place while I weld of grind it. I have some more stuff done, the bumpers are complete and in primer. The torque arm is done, painted and installed. The cage is completely welded, ready to be grinded, primed and painted. The trial run will be this weekend at a local "mud run". They have trails and some obstacals. I'll get more pics soon!
David
SpareParts
SpareParts
After wheeling it for almost a year, I'm finally taking the time to straighten out some panels and fix the rust. I'm tiered of it being multi colored another words.
Heres a couple of pics, I don't know if I'll show the finished pics till after OCBR?
sprdv1
REBEL
Get Rrr done big boy.. I still think you need to make it up to Mudd's on the
16th... :)
SpareParts
SpareParts
We'll see how far I get, I would like to make it, I just don't see it happening.
Here's some more pics from tonight.
SpareParts
SpareParts
Here's some more progress.
SpareParts
SpareParts
Almost ready to paint, I have the body work on the doors left. I still have to prime/seal everything then spray the bright silver on.
SpareParts
SpareParts
Thank you JHD, I probably have more than triple of what I have posted.
SpareParts
SpareParts
I got done with the paint last night, bright silver with a bunch of pearl and some metallic. Assembly will begin on Sun. I used Nason full base paint, 2 stage, base and clear.
tasker
all knowing of nothing
NH
Can't wait to see it! great build thread.
