Speeod gear replacement cause of 33" tires, what tooth count needed?
reamer
I currently have a "white gear", 19 tooth, but changed from 28" tires to 33" tires, Speedo off now.
65HPH (actual by Waze satellite) is reading 73 MPH on speedo. do I need to go up in tooth count?
Yes, up the tooth count on the cable side. That slows the cable down.
19 tooth and still reads slower than actual, you must have some steep gears in it.
reamer
reamer
Well that was not correct. took out the 18 tooth (40mph on speedo dial = 44 actual) and installed a 19 tooth. now 40mph on dial reads 46-47......
Viperwolf1
electron whisperer
Something isn't correct. Should be no way to get speedo close to correct (within 10 percent) with 3.50 gears and 33" tires. A 19 tooth driven gear should be closer to 20 percent off. I'm going to say something wrong with the drive gear in the tcase or cable or speedo itself.
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
Maybe this will help?
B.ranch
Newbie
Seems like when I changed my Speedo gear, they were color coded and burgundy was for 33s but I'm prob remembering wrong it's been a long time ago
GENERALLY speaking one tooth is 5 MPH
At about 60MPH. Important detail. As being off by 5MPH at only 30 would be twice the error.
More correct, the error is a percentage error. If the tire size or gear ratio changes 10%, the speedometer error is also 10%. Not a fixed offset error.
reamer
reamer
The winner is... 16 tooth! Dead nuts on, 40 =40, 60=60!
