Okay the blue wire that is alone on the ballast resistor is ign power white and purple wire on the other side is start and I term.
You don't need both. The White is the one that should be on the coil side of the resistor, but if the Purple is the only other one, then the installer re-purposed a length of Purple "START" wire to power the coil.
That's acceptable, but now it's good that you know what's what.
The purple start wire runs from the resistor straight to the negative side of the coil and is ran on it’s own it doesn’t go through the plug in the harness.
Are you sure it's the negative side? Should be the positive side.
On an ignition coil, even though it will "work" when wired in reverse, it's not correct and not doing it's full job from what I understand. You need switched power to the positive side, and "trigger signal" (basically a ground) to the negative side.
Each time the negative side of the coil is grounded, you get a spark.
The purple start wire that is part of the plug has been rolled up and taped for some reason.
Centech provides two separate Purple/Violet START circuits. One is shorter than the other, runs directly from the ignition switch to the starter relay's S terminal. This is for use with a manual transmission.
The other is a longer one and is intended for use with the neutral safety switch on an automatic transmission.
Are you running a manual or auto trans?
The ignition is a Mallory e- spark.
That's a pretty bitchin' distributor if I remember. If it's the one I'm thinking of they released it just before I stopped working as a sales rep for them. They had the "E-Spark" and one other with a fancy name, and both were very high tech, with a built-in MAP sensor and pre-programmed spark curves.
Not sure what kind of trigger module they used, but it sure looks like a Uni-Lite type. Maybe this is not the same one I'm thinking of after all.
Does it have a built-in hose fitting for a vacuum line? Or a standard vacuum advance canister?
And there is a green red and brown wire coming out of it the green wire is hooked to the positive side of the coil and red wire is connected to the negative side of the coil along with the purple start wire.
You need to verify those locations and swap them around if it turns out to be the case.
The Green wire is the trigger and should be on the negative post.
The Purple and Red are 12v switched and should be on the positive post.
Brown wire is attached to the block with negative terminal coming off battery.
Must be a ground then, and must be correct or it would not work in theory.
But it would not hurt to find a wiring diagram just to be sure.
Why would there be a separate purple wire that is ran straight from the resistor to the coil?
If it's straight between them, then like I mentioned above it's probably just some wire that the installer had laying around.
Because it's only connected to the resistor at one end, and only connected to the coil at the other end, then it's original START purpose as printed on it is no longer valid. It's now just a power wire for the coil.
But again, it should be on the positive side of the coil.
Looks like I’ve got a mess here but it ran like this for the past year and a half I’ve had it and haven’t touched or switched any of the wires
It
is a mess.
But hey, like you said, it worked!;D
The good thing is wires don't care how they are routed, as long as they begin and end in the correct place. Everything else is just cosmetics, unless it's routed in such a way as to be dangerous. Such as when up against a moving part for example.
Glad it's running now!
