The joys of survivor Broncos, fuel sending units
hyghlndr
Hockessin, Delaware
If you are struggling with it running right, it is worth starting with the gas tanks. I was surprised to see the condition of these in a virtually rust free Bronco. 20231001_100935.jpg
ared77
Wow, hard to believe. I'd agree, it appears gas tanks and related would be a very good place to start!
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
Survivor is the correct word here! I have had several Broncos with the original sending units and they looked dull, but never coated in gunk. That tank was a swamp.
gnpenning
Bronco Slave
Been working on getting my convertible back on the road. The last several fill ups the fuel gauge wasn't working. Having old gas in the tank I decided to drop the tank. The tank sock was torn. The end of the pickup tube had some buildup. The return line was clear. Turns out most of the tube was clogged. Looked like coagulated rubber. Dug out all I could and put it in the ultrasonic cleaner for several heated cycles. Finally cleared.
Amazingly the outside was much clearer than those. Replaced all fuel soft lines.
H
hyghlndr
Hockessin, Delaware
Believe it or not it is the yellow Bronco, I bought from you years ago. I has been up on a car lift for a couple of years when other projects got done first.
H
hyghlndr
Hockessin, Delaware
I think the ethanol fuel is causing a lot of this, dissolving and melting rubber hoses. The inside of the tank was awful too, the outside was rust free in amazing shape.
This for a ‘73 by chance?
Did you happen to get any pictures of it? If not, is it still out where you can get some good shots?
They’ve been documented to a certain extent over the years, but it would be nice to have some more detailed pictures of one of the unicorn return line sending units.
gnpenning
Bronco Slave
I concur, that's the reason I updated the fuel lines.
Updated the fuel lines on my 66 after going through the carb and seeing all the black in the bowl.
gnpenning
Bronco Slave
Paul, I wasn't very clear about the vehicle, it was my 69 firebird convertible. No I didn't take pictures, I'm not very good with doing that. When I'm working on something I don't even think about it. Down the road I kick myself for not taking pictures, apparently I don't kick very hard since I keep doing it.
Sorry I couldn't help.
The biggest take for me is how destructive ethanol fuel is on old fuel systems.
blade
Maker of sharp things
Santa Fe
Put sta-bil fuel additive in anything you keep parked or don't use often. My dad uses it in everything, He had a truck parked and not run for five years and when he sold it we fired it right up and the new owner drove it 40 miles with zero problems.
I always forget to take pictures too!
And, I always forget to put Sta-Bil in because I always think I’m gonna be running the engine again soon.🙄
LUBr LuvR
Dropped tanks when chasing a fuel delivery issue. (PO sold it as he wasn’t driving it much). Similar findings. Main sending unit was fine, reinstalled. Aux tank - not so much....
Only run non-ethanol fuel and try to keep the tanks full. Would rather feel the pain at the pump rather than deal with the damage done by ethanol.
