Outshine2
This will surely be a long post, but I know you guys need something to do at work!! ;D
I'm thinking of swapping in a complete (from carb to pan, fan to flywheel) 351W that I think was already in an EB. I'm told it has good oil pressure and compression but may need a tune-up (not sure what that means).
Right now I have a somewhat recently rebuilt (about 30K) smooth running 302. I'm pretty happy with the 302, except for 3 things. 1. It has a tick from the passenger side valve cover, slightly noticable when driving (if the radio is quiet and the heater is off) but it's much more noticable when the engine is cold. 2. It doesn't have much power. 3. It gets poor gas mileage (around 8mpg, yes I know it's an EB )
I'm hoping that by going with the 351W I will be helping on each of those points. It should surely have more power than my 302, and hopefully since it won't be working as hard I could squeeze some more MPG's out of it.
I have a few installation concerns though... Assuming that this engine came from an EB what mods to my '75 will I need to make? I think was previously bolted to a manual tranny, will I need a new flexplate to bolt up to my C4? Will my stock exhaust manifolds bolt up? What about my stock electronic ignition? How about the radiator/cooling system (never even gets close to over-heating right now). Will I need a body lift? What about smog equipment, will the air pump bolt up to the 351 the same and will it remain smog legal if so (may be moving to Cali in the next few years)? Anything else I should consider?
Finally, how hard is the engine swap? Currently I have no equipment (engine stand, hoist, etc...). I may buy a stand and rent a hoist? It doesn't seem like that complicated a job in these older vehicles...
My 302 is in good shape, I was just about to start spending $ to upgrade things like carb, ignition, air filter, exhaust... I can get this 351 for less than the price of doing those on the 302!!
What do y'all think?????
