I’m rebuilding my column (3 on the tree) and adding a custom collapsible lower steering shaft from Wild Horses. My upper steering shaft splines were toast, so I bought a new shaft from Tom’s.
There’s a “valley” in the lower splines - should I align the set screw with this valley? Or should I put the shaft further in the u-joint and notch or drill the splines for the set screw?
It seems like the set screw tightened into the valley works pretty well (dry fit and there’s no play) - maybe that’s what the valley is for?
If I push the shaft into the u-joint all the way it interferes a bit. When the set screw is in the valley the bottom of the shaft is basically flush with the inside of the u-joint.
Set screw aligned with valley:
Shaft all the way in:
