I tried every grommet and boot I could find when doing this and eventually decided that this marine boot with a zip tie end would work for me, but now thinking it just might be too rigid to work right. I’ll still try it and see for sure but even if I get it to work, it might not seal well and I’ll have to fill the space with foam or something.
It’s really hard to tell from the pic, and part is blocked but this is at the firewall end of my console. 3 cables are going through and they are all together but too rigid to be touching all together. Hole is about 2” and this is a 2” T-H Marine Cable Boot that has a zip tie integrated at the end.
Now that it’s all together, I’d need a split boot as there is absolutely no way to take off the Dana 20 shift cables (and the 3rd cable is my AOD B&M shifter).
If this boot were softer rubber, it could bend no problem and go against the angled tunnel, but that angle is the problem.
I just tried and no way, it won’t go against the tunnel surface where it needs to attach.
Anyone have any ideas? I can’t seem to find a soft split boot.
