UPDATE>>> What I found was the clutch alignment tool had a lot of play in the crank, so I wrapped the end with tape until it was a snug fit. Then I realigned the clutch. It eventually slid in. It also helped that I divorced the trans and tcase. Luckily after messing that up, I had a local Bronco buddy that had a spare 3 speed and I used that. The trans jack cradle I borrowed was useless. I made one with some blocks of wood that way way more useful. <<< What am I missing? Pulled the 3 speed manual and tcase together to put in a new flywheel. The flywheel is the only thing that is new. Got the flywheel and clutch installed, used a clutch alignment tool. I am using a transmission jack. The bellhousing is attached to the transmission so the throwout bearing is in place. I bought some longer bolts for the bellhousing to engine and have them all started. It should be aligned or pretty close. I think I have the splines in the clutch, but I still have 1" to go and it won't go. What am I missing?
