It depends upon what you mean by triple stick. Do you mean a single tranny stick plus a Dana 20 twin stick? I have a triple stick in mine which includes the front transfer case (doubler) and a twin stick on the rear transfer case. I have a 4th. shifter as well for my tranny but that is separate from the above. Perhaps if you can explain in more detail what you are doing then one of us can give more detailed help.
I am using a 203/d20 doubler,so I am just looking for the t-case/doubler triplestick setup.I am also using a lokar shifter,so in all I will have 4 shifters in the cab.
hope that clears things up
when I installed my coldduck I used the wild horses J-shift twin stick on
the dana20 and then a straight shift lever (I think it may just be the stock
T-shift replacement handle) on the coldduck. I don't have any pictures
showig the attachment to the adapter or transfer case. I've attached the
one picture I have showing how they come through the tunnel. the dana20
twinstick comes through the normal Tcase hole and the coldduck mounts
off the right side of the adapter.
