And to add to what they already said, in case you're wondering there are no other VIN stampings on a Bronco body. It was just the warranty plate for the body, and the VIN stamped into the frame that identified the vehicle.
And these VIN's are short, so there is very little additional info embedded therein
Pretty much model, engine type, the plant it was built in, and the sequence it was built in.
So you can tell approx. when it was built and with what size engine, but that's about it.
All other info is on the Warranty Plate which will have the axle codes, the DSO to show where it was originally delivered, and a couple of other items.
And precious little (to nothing) else on the Bronco would originally have reflected the VIN either. No engine block markings, no axle markings, nothing that would have tied a component to a particular Bronco.
Since it sounds like you have the dash, if it was something unique such as no radio hole or the optional holes for dual-tank switch and hand-throttle knob, there might be a hand painted number on the backside that matches the last few numbers of the VIN to tell the assembly line worker which Bronco to install it on.
