Those parts are a VSS. Just mounted in line on a cable instead of directly onto the transfer case. Those would mean even more parts (adding a spedo cable) and probably even more money then just getting the Atlas with a VSS to begin with.
okay, i am picking up what you are putting down---they do seem like their own little vss. according the installation manuals for both the
Summit and
Autometer versions the sender replaces the cable...it is plugged into the tranny/xfercase on one end, w/ a capped provision on the other end should you decide to use cruise control. the way i read the instructions, it shows the hall effect sensor plugging directly in, before a speedo cable would. not trying to argue w/ you here, but the way i read the instructions, i am get conflicting info....
after a little more digging, the Atlas 4spd manual (p20) states that the standard case accepts a stock speedometer from a 1997 or newer Jeep. that should indicate that the hall effect sensor to drive an electrical speedo would be autometer pn 5291 which is roughly $60.
As far as the VSS, I would prefer to run it, but my research indicates that the stalling issue is only associated w/ manual trannies. For the atlas, I have found no information that indicates that their VSS tailhousing option is compatible w/ a ford VSS...they only mention GM. The GM and Ford VSS both use different signal waves and PPMs, which could potentially confuse the computer. so it sounds like i am SOL on running a VSS w/ an atlas unless I spring for
This dakota digital signal interface, which seems like a waste of cash at this point...
