Hercfe9
Just installed a new centech wire harness and my water and oil press gauges read high. when I turn the key on the water temp goes full scale high and when I start it the oil press goes straight to above 90 psi and there is no movement even at idle. I assume if it were a grounding issue the gauges would read zero?? Any help would be great thanks. I replaced the oil and water sending units.
