Thanks for posting that up Skip. Was going to do it after talking to you yesterday, but it's better with pics.
Went in the back and looked at Jim's Bronco with the MG starter and it doesn't have the issue. Sorry I didn't take a picture at the time, but got sidetracked and also spent some time trying to figure out what the difference was.
Both similar engines (302 and 351w), both with WH shorty headers, both with stock frames.
Two differences I could see:
One difference is the oil pan, but seeing pics of Steed's pan (just a stock one) doesn't look like the pan would be an issue. Jim's is a fancy schmancy baffled affair with bumpouts and all. Still didn't have any trouble hitting the pan.
The other difference, and perhaps this is the biggest difference, is that Steed has an automatic I think, while Jim's is a manual trans.
I didn't have an auto version on the shelf to compare to the manual unfortunately.
The top bolt like it Steed's pic was readily accessible with the usual long extension. Maybe a wobble joint would help, but it was at least doable without resorting to a wrench. And the subsequent fraction of a turn at a time!
I actually wondered if it was clocked 180 instead of just enough, if that would work. The solenoid doesn't really care what location it's in, and there should not be any issues with hanging too low I wouldn't think. Curious about that and will look into it.
Sorry about the hassle you went through to get yours installed there Skip. Hopefully it lasts the life of the engine before you have to tackle it again! But I'm still going to check into options. I'm still going to install one in mine too, but that's down the road a ways still.
