mduenas
I feel absurd asking this, but I had a 351w carbureted and always used 91, now I have a 302 with fitech, should I use a lower octane?
I have to use 91 octane too. Don't know the specs about my motor, but I have a little dieseling when I shut it off using cheap gas. I've tried adjusting timing with no luck and I don't want to put on an anti-dieseling solenoid. Plus, literally a couple bucks each time I fill up for better gas is worth it.
Higher-octane gas is NOT "better". It contains less energy; it's harder to vaporize, which means it doesn't burn as well; and it costs more.
What I meant by “better” was less volatile. I guess all the tracks in the nation shouldn’t carry high octane fuel. Or higher performance vehicles shouldn’t use it. I’ve always thought is keeps the engine running cooler. I know from personal experience also you get better fuel mileage too. A long time Ford mechanic family friend suggested it went we looked at the dieseling during shut down. It happened to fix it in my situation. I’m not an expert just my life observation.
=====What I meant by “better” was less volatile.
High octane fuel is good for preventing knock or "dieseling" (pre-ignition).
It will not give better mileage EXCEPT that it will let you run more ignition timing advance, and more advance will give better mileage...So in a case like that higher octane will allow the computer to keep the advanced timing that gives better mileage.
If you are going to run high octane on a stock-ish older engine you should set the timing with high octane to put you just below knock.
You are misinformed regarding Volatility. The gasoline at the pumps all have the same vapor pressure. Which means none are more or less volatile.
As you now have more knowledge from several correct messages above you should be using the lowest octane that does not cause detonation.
Of Course if you have a Coyote motor the above is not applicable because higher octane will give better performance for that motor.
PaulW
Sorry if I didn't use the correct words/verbage. The point I was making was if the fuel is igniting prematurely wouldn't higher octane help that. And to a layman if something is igniting prematurely/sooner/quicker it is more flammable and more volatile.
The main function of a carburetor or fuel injector is to vaporize the gasoline. And volatility is the tendency or ability of a liquid to vaporize. So low-volatility gas is "worse".What I meant by “better” was less volatile.
That's exactly backward. High-performance (high-compression) engines need fuel that's hard to burn so it doesn't pre-ignite (before the ignition spark). And yes, there are vehicles built that way. But your eB isn't.I guess all the tracks in the nation shouldn’t carry high octane fuel. Or higher performance vehicles shouldn’t use it.
Right, which is bad for power & economy. The hotter an engine runs, the more-efficient it is. That's why jet engines are so much more-efficient than piston engines. So by making your engine run cooler, you're making less power & burning more gas to go the same distance (lower economy). It's just like putting water or other contaminants into the gas. In fact, contaminating gas with ethanol is one of the cheapest ways to raise its octane.I’ve always thought is keeps the engine running cooler.
I don't claim to be an expert, either. But my life experiences include college chemistry, physics, & thermodynamics; being the son of a professional petrochemical engineer; working in the auto repair industry for over a decade; and reading several Ford TSBs on this subject. You can read them, too, at the link I posted above.I’m not an expert just my life observation.
Not according to Ford & the EPA. Winter-blend fuels are more-volatile than summer-blends.The gasoline at the pumps all have the same vapor pressure. Which means none are more or less volatile.
Only if they're built to use it, and are labelled for high-octane gas. Most modern EFIs are built for 87 or lower (E10-80).Good, so in my modern cars with fuel injection I'm not going crazy and do get better fuel mileage.
No, flammability is not directly related to volatility. You're confusing terms you don't seem to understand. Each word has its own meaning - you can't just lump them all together.And to a layman if something is igniting prematurely/sooner/quicker it is more flammable and more volatile.
That's somewhat misleading. It burns at roughly the same temperature, which results in roughly the same pressure-rise. But it IGNITES at a higher flash point (harder to ignite), and it's commonly used in engines with higher compression (pressure). The higher flash point & lower volatility are why it's suited to high-compression engines.Since higher octane fuel combusts at a higher pressure/temperature, it would help with pre-detonation.
You can read them, too, at the link I posted above....You're confusing terms you don't seem to understand...
