Our bronco came with some sort of aftermarket system. The booster is bad and I want the most powerful one I can fit. It is currently a 7” diameter, 6 3/4” long body. The master cylinder mounts are 3.25” wide. The mounts to the brackets are 4 but not square. The top outside is dropped down. The other three are 3.5” apart. The dropped one is 3” from the one below.
I have 3/4” clearance to the hood from the current one so I figured a 8” dual diaphragm would be good. The depth of it isn’t critical - I have room to play. But the mount is off. Is this a Ford bronco mount??
What should I order? (Besides hydroboost.... hopefully soon. I just need to get it back on the road)
