Will a power brake booster/master cylinder/prop valve assy clear the top of a '66 - '72 inner fender, or is the '73 - '77 inner fender required for clearance?
More kits that will fit than you can shake a stick at! All will fit and are in stock at this time. Depending on tire size I would point you in the direction of one of the Hydroboost systems. https://www.wildhorses4x4.com/category/Bronco_Power_Brakes
Stock 66 only need to also consider additional parts: Hard lines, brake light switch. DM for tech help if needed.
If that picture in your profile is accurate, stop looking at vacuum booster and start looking at hydroboost.
Lot of people have upgraded from a vacuum booster to a hydroboost. Don't know anyone who took off a hydroboost once they got one.
