- May 27, 2010
- 299
I am going to be buying a new battery and thought there was some talk about the preferred side of positive and negative battery terminals any opinions?
Thanks paul,and it's no big deal that the cables will cross each other huh?Should i add a bit of protection somehow where they cross?Factory position had the positive side away from the engine, and unfortunately, too close to the fender lip. Actually underneath it in some cases.
Most of us have replaced our old batteries with the reverse terminal so that the positive side is towards the radiator and the negative side toward the body.
Figure it’s safer that way, especially when working with larger than stock batteries.
It’s been so long since I’ve bought one based on that that I may have forgotten the proper terminology. But I believe the stock bronco battery is a 24F (F for Ford). The preferred battery is just that number without the F.
Or a larger 27 type. Many of us have upsized the battery to get more cranking amps and especially a longer reserve capacity.
that makes sense,like the pic 1969 put up right?or, flip the stock battery around so positive is not only toward engine, but away from core and side body.
now that's the perfectly oriented battery!where are these interstates sold?i didn't see them at napa or autozone's site.Depending on how long your cables are and how the battery is oriented in the tray. You could possibly just flip the battery around so the positive terminal is closest to the engine. Or if you’re a like me and OCD and want to read the labels correctly when you open the hood you can get a group 24 battery.
Thank you sir!I am a big fan of Interstate Batteries. You can use their website to find the closest dealer to you.
[/URL]
It’s not a big deal if they’re not touching!Thanks paul,and it's no big deal that the cables will cross each other huh?Should i add a bit of protection somehow where they cross?
Thanks paul,i can get a bit longer negative cable which would eliminate any issues with coming into contact with the positive cable and i did find an odyssey battery that has the terminals in the most optimal position when turned around,which isn't easy to find a battery like that,lol,this one has 725 cca,thoughts on odyssey as a brand?Also you can get 20% off right now on them which would bring it down near the price of this other battery which i do have in my other truck going on 4 years and love it.It's a duracell platinum,the terminals aren't going to make it optimal if you turned it around like the odyssey as it would be near the grill but it has 750 cca.Same 3 year warranty,just wondering which would last longer.Would you go with a bit less cca's with the odyssey and be able to have the terminals in the best possible spot or is cca's king?It’s not a big deal if they’re not touching!
But it can be a HUGE deal if they are left unprotected, while crossing over each other and in contact.
Never let them do that.
Or make sure there is some secure sleeving around them. Sleeving of a type that is not likely to ever wear through.
if you’re getting new cables anyway, it’s easy to get them the right length that they don’t physically cross each other.
Thank you i'll give them a look!COSTCO carries Interstate batteries.
Thanks paul,i'm leaning towards the odyssey myself,there is one interstate i've seen for my bronco,the super premium that has 800 cca's and a 4 year warranty but their terminals aren't in the optimal spot even if you turn it around and not sure if that's a deal breaker anyway but they're 420.00 as compared to about 280.00 for the odyssey but it seems like their top of the line for broncos,hmmm.Also you're right about the gauge of the negative cable,i can get a 2 gauge for a few dollars more,thank you sir!I haven’t heard anything to change this, but up until at least recently, Odyssey were considered one of the best. I normally don’t like to sacrifice CCA’s, but for an odyssey at 20% off, I would probably do it.
Nothing wrong with interstate either, but Odyssey are pretty highly regarded as well.
If you’re gonna get a slightly longer negative battery cable, don’t go cheap or too small. I think most of us here consider 4-gauge a minimum. With 2-gauge even better.
And considering it’s a fairly long ground run, going a little overkill on the size doesn’t hurt. Doesn’t even hurt the pocketbook more than a couple of dollars either!
Thanks paul,well as far as being able to find a battery with the positive terminal in the most optimal position whether you needed to turn it around or not the only one i've found so far is the odyssey.Not sure i'm overthinking the whole optimal position of the positive cable i was just going off what people have said and it made sense to me,lol.And I’m kind of surprised you’re finding it hard to find the correct battery. At least in the old days, that was probably the single most common size.
And the regular, non-F type, was by far the most common as it fit in most other vehicles, including some Fords.
