countrypyhysician
I have a US Shift Quick 4 control module to my 4R70W transmission on a 1974 Bronco. Ground is hooked directly to the battery. Power is run to a 12V igntion wire (peach) under the dash. In the on position, solenoid B constantly clicks and the transmission module buttons malfunctions. Once cranked it functions fine. Over 200 miles driving it. After talking to US shift, he thinks it is a problem in the ignition wire as I am only getting 11.2V (tested with a multimeter from the battery negative to this wire) from the ignition wire. It needs 12V. This is a picture from under the dash of the peach wire the mechanic used to tie in this pink wire for ignition power. Does anyone know what the peach wire's function is and why it is dropping voltage? Also, any suggestions for another wire to use for a 12V ignition power?
