4r70w column shifter options FOUND AND DONE!!, see page 2
dnewman9
I can't imagine a factory column shifter better than my setup.
I have the Lokar selector in the transmission, with an ididit cable and column mount. This is on a 78/79 tilt column and although the column has issues, (bad bearings), it shifts solidly, accurately and the line matches up with each letter perfectly.
I seriously doubt brand new column shifted automatics shifted this well!
Let me know if you have any questions, I spent a bunch of time on this for my build and as you can tell, am pretty happy with the results.
Dennis
dnewman9
BTW, I started with that exact kit from Jegs, and could not get the rod to work right, which is why I added the ididit cable and mount.
Bronchole
Chatsworth, Ca (LA)
I used the cable from the Mountaineer that I got my 4R70W from and the factory Bronco automatic column. Ran the cable over the top of the column and made some brackets to hold/adjust it. I got the idea from some pictures I saw here.
G's Baja Bronco
Sunny SO CAL
what year moutaneer? I imagine the explorers are the same.:cool:
66horse
Dennis
Dennis,
Can you give a little more detailed writeup on this? I have a 78 column that I am thinking about putting in soon. Would like switch form my floor shifter to that column.
Thanks.,
Steve
EricLar80
I have a B&M floor shifter with mine, but I had to make the shift bracket myself since they didnt make one for it.
Eric
kurtboyd
Cave Creek, AZ
Eric
How do you put in OD? Do you have any pics? I have a B&M Quick Silver floor shifter. I wonder if it would work work with some mods?
Dave
That is automatic in the D position. OD off is a push button that you can put anywhere.
bronco loco
bronco loco
It never ends
Long Island New York
For those who are looking to use their stock auto shifter column with the 4r70w, you need this kit: LOKAR ACA 1808
bronco loco
bronco loco
It never ends
here are some pictures. First picture shows the lever on P
