build thread III: preassembly, reassembly, paint and . . .
backpain
Well, just about all that has happened since ( link below) is progress toward completion of the center console.
previous thread - http://classicbroncos.com/forums/showthread.php?t=168603
- 2 piece, bolts together and to floor
- Art Carr(Winters) shifter and cup holders go in the lg holes
- power port hole
- room for switches, etc
- covers from just behind the seats to about 8" up the trans hump
- painted to match what will become the body color (brighter shade of existing body color)
Oh yeah, POR covering the entire underside of tub, frame and axles is now complete, 23gal tank fitted and skid plate mods in process
If weather holds, tan bedliner goes in tomorrow . . .
Fitz24
That's looking great. Wish I could do something similar that would fit with a 1/2 cab bulkhead.
Heus33
Wow - that looks great! Can you tell me the dimentions? I'm looking at center consoles now and might pick something similar. Thanks!
B
backpain
Sure, I'll measure, but if I did it all again, I'd probably take a Tuffy, strip it and add to it to house the shifter.
Mine started out as a sheet of metal. Lot's of labor (not mine and $expensive - I designed it but can't take any of the finish work credit). My non-stock seats are mounted in off-stock locations, so this was simply made as large as would fit between them.
If I were going full custom again, something like below would be great, but the way I mounted my seats, seat width and remaining room between, would leave some funky transition to the dash given the off-center tranny tunnel. I ran out of creativity and kept mine simple . . . and then the shop owner busts out with this for his own car . . .. Sir, thanks for saving the creative juice for yourself :)
Shoot me a PM to remind me if you still want specs on mine
aliensecretion
Wow! Looks great. What color is that? I think that would look awesome with a Wimbledon White top and interior!
Heus33
Actually thats kind of where I'm headed - start with a Tuffy and build the front section later. I'll definitely look to yours for some inspiration - thanks!
Scoop
Bronco Old Fart
Cuchara, CO
Personally I like what you've done better. The square corners match the Bronco dash much better. The real fancy ones look like they've been pulled from another vehicle while the simpler ones look like they could have been stock. Lot's of Broncos with fancy interiors look nice and it's apparent that lots of work went into them, but they look way overdone. Keep it simple!:cool:
Sylar
Cleveland, TX
wow, thanks for the inspiration, I have a Tuffy and was looking to modify it, your console gives me ideas hehe. I can put some switches or 12v access points on the "wide side" of the console to help with the "off-centerness" ought to be interesting with the twin stick too ;D
B
backpain
a few more ctr console pics
B
backpain
And some more tan bedliner pics. This is:
1. new and/or stripped, rust free metal
2. epoxy primer
3. Lizard Skin SC
4. Lizard Skin CI
5. Line-X w/Xtra
The color came out a shade or two lighter than expected, but I'll probably leave as is. Once it's covered up with seats, dash, etc. I think it won't bother me as much.
B
backpain
. . . and here's a few general progress shots.
OK, now looks like that core support still needs some straightening (. . . and, of course, needs to be cleaned up and painted)
Sylar
Cleveland, TX
I am really liking the console.. is the square opening in it for the shifter to poke out? Or does it sit like it is in the pix? edit: NVM the front cupholder would be under the dash if it was moved forward .. my bad :)
B
backpain
The rectangle is for an Art Carr/Winters c-4 shifter. The gate and above show, everything else is inside the console. The transfer case shifter will just have a bezel and boot . . . but you have me thinking . . . .
Sylar
Cleveland, TX
Oh I see now, was throwing me off how it fit the floorpan like it is hehe. The angles look similar from eyeballing them on the picture ^^
B
backpain
More random pics. This time I can't take any credit except for ideas. Someone else did the metal work - especially the curved piece of the radiator cover (I'm no artist on a shot bag)
- radiator cover. will end up either black or body color; it's in unfinished mild steel right now
- inner wheel well/core support brace cover with overflow sunk in (to match the one we did on the other side when we relocated the battery)
- BCB's blank dash w/glove box moved over 4"
B
backpain
Here's the seat heaters that will be going in.
Rostra 250-1870; $57ea x 2. Each has seat bottom and a back.
You can see from the pictures that the bottom may well need to be trimmed. They are trimable.
Thought I'd show pics for others, as I always want to know what I have to play with in terms of relays, switches and wiring needing a home so I know where I'm going to hide it all.
.94 OR
Willamette Valley, OR
Are you heating leather seats or cloth?
I have heated leather in my pickup and the thought crosses my mind for my EB, but with cloth, I'm not sure the heating elements would hold up as well.
B
backpain
Cloth (tightly woven vinyl, or Bestop's "denim vinyl") for me.
These are pretty well packed in a wool felt-like blanket, so I am not worried about the seat so much. Without a top in Texas sun get's the surface of any seat hotter than any seat heater I am aware of (because manufacturers won't sell seat heaters that burn you - but the Texas sun on cloth can come damn close and on vinyl will for sure)
Rostra sells another model made for leather that gets even hotter.
A handful of folks here have done inserts and may have more input - do a search on seat heater and you'll find a few more posts.
As for the elements, as I said, packed in a fairly dense material. I'm not worried about folding/creasing, doubling up/shorting. Water is always a risk - even with leather. As long as they dry out before use, usually fine (excepting for total submersion or extremes - but still, the elements aren't the problem - its all the other connections and relays, switches, etc mostly as risk.). They will be connected to fused power of course.
