BCBroncos Wristed Axle Housing /
howiebilt
Bronco Buddah
Newton
Chuck ,
I am to the point where I must hone the inside of the axle tubes and I have spent 6 hours and I still can't get the sleeve to fit in the housing side of the differential . I haven't even started the outer tube yet ! I hope there is an easier way ... ? Please help .
chuck
Ingram, Texas
Re:BCBroncos Wristed Axle Housing / Problem #1
The 2 that we did for the EB housing did not take much honing. We used a engine cylinder hone
and in about 10 min. we were done with that part. Could you mic the bore and sleeve for me to see
how much off they are? Also check a couple of places to be sure everything is round. The idea was
to get a nice clean hole, no to have to resize it. Let us know.
P.S. did you make a chamfer on the inside of the opening? We found it hard to get the parts started
togather but after the first 1" it went fine. Also I assume you do not have the O ring on at this point.
howiebilt
howiebilt
Bronco Buddah
Newton
I used an engine cylinder hone with coarse (100) grit stones . The first 2 1/2 to 3 inches were a piece of cake , no problems , but that last inch was kicking my butt . I marked the end of the sleeve with a black marker and pushed the sleeve into the tube until it would go no further , then I gave it a slight twist and pulled the sleeve out . This tranfered the marker to the high points for me to see with a flashlight . Then I used a die grinder with a large stone wheel and removed the high spots , followed by more cylinder honing and then I would repeat the process .... 7 hours of this and I finnaly got it . The outer tube took , as you said , about 5 minutes and it was perfect . If I had known that it would have made a difference , I would have made the cut 1 inch further away from the housing .
howiebilt
howiebilt
Bronco Buddah
Newton
Another thing that needs to be changed on the instructions is the size of the drilled hole on the outer tube for the 1/4 X 28 tpi grease zerk . It says to drill a 1/4 inch hole on the top of the tube , but it should be smaller .
chuck
Ingram, Texas
Now that you mintion it we did have a little trouble getting the sleeve to go all of the way into the inboard side. I think the tight fit of the tube into the casting makes the tube a little smaller. With the 2 that we did here we installed the O ring, lubed the tube and sleeve up and used a rubber hammer to set it. Forgot to write that part, sorry. I will include that and the correct drill size in the new instructions. I wanted the sleeve to be inside the casting and that is how I decided how far to insert the sleeve and where to cut the tube.
howiebilt
howiebilt
Bronco Buddah
Newton
That was a nasty little trick you pulled on me Chuck :eek:<br><br>The drill size should be a #3 or .213" drill . <br><br>I am going to assemble the whole unit now and see if it bolts up ?:? I'll be back 8)
Jeepster
[quote author=howiebilt link=board=5;threadid=12902;start=0#97119 date=1041706716]
[/quote]
price of doing bussiness. ;)
Keep up the good work Howie. Look at it this way
not only will you be a "tech writer" you could also have a 2nd title......"guinea pig" :eek: :eek: ;D
semprbronc
Magnolia, De
I wonder if the Chuck/Howie connection will be so amicable at the end of the project ;D ;D ;D ;D Great info fellas. It is really great to get this perspective on a new product.
chuck
Ingram, Texas
[quote author=howiebilt link=board=5;threadid=12902;start=0#97119 date=1041706716]<br>That was a nasty little trick you pulled on me Chuck :eek:<br><br>[/quote]<br>Was not by intent, I forgot.
howiebilt
howiebilt
Bronco Buddah
Newton
I am having another problem with the bolts that were supplied in the kit . When I got the parts , I checked to see if the bolts fit in the tapped holes and they did but now I have come to the realization that the holes were not tapped deep enough or else the bolts are just too long . I notice that no lock washers were included in the kit and there is no mention of thread locking compound being used in the instructions . The bolts appear to be about 1/8" too long and a washer with a lock washer would take up this extra length . If it's alright with you , Chuck , I am going to substitute with shorter bolts (1/4" shorter) and use some locktite instead of lock washers , that way I can be sure there is enough thread engagement in the hole .
ChrisinWV
St George Island, MD
[quote author=semprbronc link=board=5;threadid=12902;start=0#97140 date=1041709976]<br>I wonder if the Chuck/Howie connection will be so amicable at the end of the project ;D ;D ;D ;D Great info fellas. It is really great to get this perspective on a new product.<br>[/quote]<br><br>I agree that it is great to be able to watch the R&D on a new exciting product........<br>You can't get sh*t like this in a magazine!!!<br>My hat goes off to Chuck in letting the community that will ultimately purchase (or not purchase) his products play a part in their development.<br>That can make the difference between a good product and a great one and is just such GOOD business!!<br>Chris in WV
chuck
Ingram, Texas
Thanks Chris, I agree. Howie, we may have mis- ordered the bolts, a little shorter with thread locker is fine. I know it is a little late now but I finally got some pictures up on my site on how we installed the WAH. Go to picture, at the top of that page is a link "HERE"
howiebilt
howiebilt
Bronco Buddah
Newton
Sounds good on the bolts to me Chuck ;) The pictures look good too ... but I have to tell ya that mine look better ;D ;D ;D ;D I took almost the same exact pictures as you did . I wish that I would have ordered new c-bushings and a longer brake hose . I can get around those problems for the testing , but it might be good to note that if you are going to have more articulation , the hose kit would be an important item to add to the list of items needed . The C-bushings were my own fault for not paying attention and abusing them for about ten years ::) They'll last a couple more weeks , I think ;D
IPwizard
NE Ohio
I have a stupid question.<br><br>Is this for the front or rear axle housing? If its for the front does it just allow the outside portion of the housing to rotate independant of the inner housing/pumpkin?<br><br>If its for the rear explain how it works.<br><br>Sorry new to all the trick stuffs.
Jeepster
heres a photo of it<br>
chuck
Ingram, Texas
[quote author=Ford_Tuff link=board=5;threadid=12902;start=0#97625 date=1041896399]<br>I have a stupid question.<br><br> If its for the front does it just allow the outside portion of the housing to rotate independant of the<br>inner housing/pumpkin?<br><br>You have it right, it is for the front. The whole idea is to relieve the bind in the front end much the <br>same way the wristed radius arm does. <br><br>[/quote]
IPwizard
NE Ohio
Very cool, You guys allways think of ways to do stuff better.
howiebilt
howiebilt
Bronco Buddah
Newton
I can tell you that it looks really nice and the table it is sitting on hasn't moved a bit ;D Seriously , the thing that is holding me back is the radius arm that has two broken bolts in it . I will get those two bolts in the morning and then the testing begins :eek: I can't wait ;)
howiebilt
howiebilt
Bronco Buddah
Newton
I just added Photo Page 4 to my website so you can see some of the pics I have taken of the WAH . <br><br>
