BroncoBub
- Oct 14, 2018
- 708
Finally purchased a Bronco. It's a 1975 Bronco Ranger in Midnight Blue Metallic Paint. Will build it back to as much as original as I can make it. Not a whole lot of rust to repair. Typical floor boards and some minor rust in the rear cargo drivers side and some minor spots on the rockers. The door post are solid front and rear. Will be replacing quarters and fenders to get it back to its original look. Should be fun. Stay tuned...Here's some photos where I found it and then some with the interior removed. Most of the outer (patina look) is light surface rust and paint faded to primer. The roof is going to need some work or might have to replace it.
Will need a C4 Transmission and Dana 20 transfer case and adapter plus the trans cross member. Overall I think is a solid project that hopefully won't take long to get it on the rode again.
Bub
Bub
