4-Link Rear with Extended Radius Arms
rguest3
I am looking for a 4-Link Rear Suspension Set-up to go along with the James Duff Extended Radius Arms on the Front.
James Duff has the 4-Link Rear which looks good - Weld On
Since calling this morning, Krawlers Edge No longer offers their Quad Link, which is really what I had my eye on being a complete Bolt-On system.
Any other 4-Link options in a kit form? I really do not need to reinvent the wheel here and work out all the Geometry. Looking for about 3" Lift.
Your recommendations, experience and knowledge are appreciated.
Yeller
Rogers County Oklahoma
I know your looking for a bolt on kit, there are none that I know of, but the duff kit is very hard to beat. It fits and the geometry is on point.
68ford
How much lift do you have? Is wheel travel something you care about? Reason I ask is if you go with a link kit that sits really high above the diff like some out there. You have to either be really tall or drastically limit your wheel travel so the link mount on top of the diff doesn't crash into the floor.
R
rguest3
I will most likely go with a 2" Body Lift to help with clearance and not have to modify the floor.
The 3" Duff kit looks good and is Complete. I would order it in Black or Raw. I was also hoping I could find a Larger Single Frame Bracket that would work to mount the upper links of the 4-Link and the Arms to the Extended Radius Arms. Stronger and Cleaner install.
Dlish
not much info about it yet, but Duff teased a newer 4 link set up coming out in the fall as well. I think more street oriented, or better for rigs with less lift. maybe worth a call
KyleQ
3" of lift and 4 link? ?:?
You're going to have to do some welding with any 4 link install.
R
rguest3
Just a FYI.
I spoke with Duffs yesterday and their new 4-Link (More Street Friendly) will not be available for at least a few more months. No time frame really.
jmhend
I am interested to see what the changes are and what makes it "more street friendly"
R
rguest3
I thought that was the point for the Sway-Bar too.
Hopefully we'll see soon what the changes are soon.
36Fan
Theres ways to link the rear and still have a low lift, you have to think outside the box and it wont be bolt on.
5001craig
I run the Duff 3.5" 4-Link and their extended radius arms. I moved my rear axle back 1.75" and in this pic you can see how close the frame brackets are to each other. If I had to guess I'd say without moving the rear axle back the two brackets on the frame would be very close.
1n528YMM9PGiHSe9b0gj0UZvnuLfzL_vWjwKRyj-k3RESVHu0sbbiihSsBjaPoY7M5Tm5jcDzxMtbyJtDUQQMc9whWAHRYd-1zqzCvcWCy3Sq4zfHqMs2a80tTNPK8s6lA9TPQQUvNfegOt002H4c4WCaElX48i1ZfGVRPq4bBFelWCc3et03uzamXZn-qw4Lsfh5uzCYvGB5-MvLrUoTHPWeDctFemLAlOyACTXi1XMQH8AMqm4ZQffQxBGLuskvQjL7Aoq45rumQVys-T5Z4qLvBq6xlY8e0k_0PD4jOLkGgRYX_0l3eTeW8EWtm_7IDZb2eorP-ICwimP827o9GGM0uJQ1433sSpFvadoTrHo-9Ks9RpKSccFCO8RPlvYRAzK0VRK3KIhpx4sZ5R9RTKAFP9cyf81sjbfKPuDSY4GzdvU5v0Es5Lw1ehQ-UN4bIXcFllrMHxrGhUfut_7Hg4Mt28aOjm0fR9JSHqj10P4JYCSbwCkSz4XrGu4aqK_WZeAySlXtj-MzQA1r3L9Ktg37VvMLvjsgKt3n5C-mLZ5LhVt6LXFo4ychBp5wxXzIsODS528_lF3zfA2qH7EFWcjL3L0xWa1j7HiC5z8AdEdY9IM003jFxme_0Kbd1o3kvbUu-wstrYgNxB9njd4RGETjoBO3uiO=w1705-h959-no
R
rguest3
5001craig - You setup looks great! Something similar on my 77 coming soon.
