All,
We had overheating issues with an AOD transmission on my 74 Bronco. We looked at all kinds of potential causes. We checked to make sure cooling lines did not run near any hot surfaces. Checked the TV cable and the pressure. We’re using the correct throttle cable “geometry” for our carburetor. In the end the solution was a second radiator for transmission only that does not share with the engine’s main radiator. Based on my experience I would expect anyone with an AOD to have a similar issue. I think you should count on running a secondary transmission radiator.
For anyone considering the AOD here is my .02 input, our configuration for reference and the solution we went with.
Firstly I recommend the AOD. We bought a new/reconditioned AOD and used an adapter from Advanced Adapters for the AOD and Dana. You will need to buy or fabricate a brace to hold it in place since its longer than the stock transmission. In my case we replaced the manual 3 speed with this. It shifts smoothly and its pretty quiet and for what we use the bronco for it’s a great choice. This is the AOD not the AODe so it has no other external electronics or computer attachments. It did run hot however and I would be surprised if everyone else doesn’t have the same experience. When I installed it we added dedicated pressure and temperature gauges for the transmission. I recommend that too. These classic Instruments gauges are good and they will light up red when you get to extremes on transmission pressure or temperature.
Here is our engine setup:
Mostly stock, flat tappet original 302 with no EFI. It’s a Holly 4brl, carb with some short hooker headers and an MSD ignition. Otherwise pretty stock. We added a new aluminum radiator and the Transmission shared the radiator with the engine at first. The fan is stock with the stock belts.
Symptoms/Problems:
When driving on longer (30min +) trips the transmission heats up and eventually runs at over 240 degrees and we need to sit and let it recover before moving again. We tried limiting the use of over drive, checking the transmission levels, looking for issues with the lines running near heat sources etc. Making sure the pressure and kickdown looked right etc.
Solution:
Finally I decided to separate the Transmission cooling from the main radiator. I used this Fluidyne unit from summit. It was expensive (I think) but its worked out great.
https://www.summitracing.com/parts/FLD-DB-30110-8AN
Pictures
We mounted it in front of the main radiator and we had to take the grill off to be able to drill and fit it properly but its been worth it so far and for other reasons we needed to be able to get the grill on and off so we took the opportunity to put new front fender bolts and clips in. Here are some photos on how we mounted it. We did have to grind a little metal to get the fittings to clear some spots.
https://74bronco.shutterfly.com/pictures/162
Results:
The results have been great/dramatic. The temp holds a under 160 degrees in all conditions now. Really happy with it so far.
https://74bronco.shutterfly.com/pictures/162#158
https://74bronco.shutterfly.com/pic...-SFLY-43737-3178588440&clickId=3178588440#161
Doesn’t look too bad (subjective) from the front grill.
Symptoms/Problems:
Solution:
Pictures
Results:
