Where do these braces go?
reamer
"door to cowl braces" do they mount in the interior or exterior (behind the fender skin)? Anyone have, or can get a photo of these installed?
Completed the "bronco in a box" in 3 weeks...Now finishing touches and take it apart for welding...
1970 Palmer
They are located just below the windshield hinge and form the ends of the cowl. The rectangle hole is for a cage nut that secures the ends of the dash to the cowl. They were spot welded together.
Sorry, that's the best I can do. You need someone to post up a photo that shows you how they are orientated.
John
Quick & Dirty
I'm in the same situation of complete body replacement, so I took pictures during the dismantling process. These may be useful.
In most of these the cowl is laying firewall down, so the orientation may be confusing.
Quick & Dirty
Found a couple more, when the dash was still in place.
The small screw hole is for the door seal weatherstrip.
reamer
reamer
So the two interlock with each other... interesting.
Thank you
