Added 80's door switches to "a" pillars, interior lights when doors open
reamer
Such a basic luxury in newer trucks, My Bronco has been updated! two under dash and one overhead light comes on with either door opens, they turn off when door(s) close...:cool:
Very cool. Where are the pics?
I've got great courtesy and dome lamps, but they are turned on manually only. Would like to see what door switches you used and where you put them.
Lots of things I've always wanted to see on Broncos that are practically on every other vehicle.
reamer
reamer
Here you go, Door switch part number included! (ya need 2 of them) Now I just need to run a tap to an overhead dome light...
papy
a good upgrade indeed! one day i will get around to it
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
FYI..."Those are long when new because they are designed to self adjust the first time you shut the door. The brass tube slides inside the nut on first use. After that the plastic plunger does it job and the brass sleeve stays put."
Original part number: D3TZ-13713-A .. Courtesy Lamp Switch (Motorcraft SW-1161) / Replaced.
1973/79 F100/350 & 1978/79 Bronco.
Replaced in 1983 with: E3SZ-13713-A .. Courtesy Lamp Switch (Motorcraft SW-1782) / Replaced
Replaced in 1988 with E8DZ-13713-A .. Courtesy Lamp Switch (Motorcraft SW-2003-A).
1973/88 F100/350 // 1975/88 Econoline // 1978/88 Bronco /// 1987/91 Aerostar/Bronco II/Ranger /// 1977/80 Granada/Monarch/Versailles // 1983/89 Thunderbird/Cougar.
1983/86 LTD/Marquis (Fox body midsize) // 1984/89 Tempo/Topaz & Continental Mark VII // 1986/89 Taurus/Sable.
