I have been looking at my Bronco since installing new axles etc. I think the way that it sits it would be better to lift it 1" at the body. More room to work, fix the air cleaner situation etc.
I am likely going to go with the integral WH kit to get the clearance. I understand that the clutch linkage may need help.
Any other problem areas? Will I likely need the rear fuel hose and if so what size should a 70 be?
I know the body lift has some fastner problems, but I think I can get around those pretty easily.
Thanks for any tips.
