needabronco
I was replacing my spark plug wires (dam mice), and was double checking #1 TDC to get the plug order right and discovered that when I'm on the power stroke (both valves closed) the rotor points to where #6 should be according to the book. My old plug routing was/is the correct order for a 302 given where #1 is currently pointing, but now I think I'm backwards?
My question is does it matter if the rotor is pointing in the right direction according to the book or does it only matter if the wires are routed correctly? The engine runs great the way it is by the way, so it is not 180 out.... Thanks...
