16" Ford Wheels Similar to Bronco Steel Wheels
Yep, rev‘s per mile is the number.
But the first thing we see are the numbers on the sidewall and the measurements on the tape.
And add a load rating of 2700 pounds, I don’t expect they’re gonna squeeze down much.
I bet they look almost full with no air pressure in them at all!
OK, so that might be a slight exaggeration. Or then again…
ford man
Leesburg Ga
Ford trucks had 16" wheel option on 4wd mainly but I have seen them on 2wd too. I have seen them all the way up to 1979 4wd trucks the wheels where painted argent that tells me 1977north. These where all the same as the bronco wheels narrow with the outer hub cap nubs. It is believed that 1973 was last year for the bronco. I run 235x85x16 on mine but bfg quit making them shortly after i bought mine. Its good to see them come back out with the 700x16 little narrow than mine but same height.
