joshnjulie1
Listing this Ad for a Friend. I will relay any information ASAP. Thank you.
Specifications
Only 500 miles since rebuild
Body – 1957 Chevrolet 3200 Long Box Pickup
Color – Lemans Blue from 1969 Corvette
All original factory body panels
Front bed panel, (against back of cab) is the only reproduction
*Modifications
**Hidden Tailgate Latches
**All body side moldings removed
**1 piece door glass, (wind wing removed)
**Gas tank relocated to under bed
**Solid White Oak wood bed, (Cabinet quality, not kit)
*Frame
**Original frame
**Modifications
***Front suspension – 1970 front clip with power steering and disc brakes
***Rear suspension – original leaf springs with 2 springs removed to lower truck.
*Drive line
**Engine – serial # V1213TMM
**V = made in Flint Michigan
**1213 = December 13
**TMM = 1980 350 from Chevrolet C20
**Transmission – stock Turbo 350, Serial # 15J147196
**Differential – 1979 Camaro 10 bolt Posi – 2.73 gears
*Engine Specifications
**350 4 bolt main bored .030 over
**Stock crank and rods
**Sealed Power hypereutectic pistons 9.5 to 1 compression
**Comp Cams 270H cam with new hydraulic flat tappet lifters
**Comp Cams 1.52 roller tip rockers
**Summit Racing Vortec heads. Part # SUM-151124
**GM Performance head bolt kit
**Edelbrock Performer RPM Air Gap Intake Manifold
**Stainless Steel bolt kit
**Performance Products balancer and ARP bolt
**Eccel performance electronic distributor with Accel Supercoil
**Holley Carburetor – part # 80457S
*Interior
**Tilt steering wheel from 1972 Chevy van
**New Leather seats from Honda Odyssey
**Complete new wiring harness from American Autowire
**Vintage Air Conditioning
**New gauge cluster from Classic Instruments with Tach.
**Am/FM Stereo from Custom Autosound with auxiliary jack for mp3 player
**Gas tank removed, allowing for storage behind seat
**Full Dyna mat lined
**Full carpeting, floor and up the back of the cab
**Leather lining on door panels
**Matching gray leather on Grant steering wheel
**All new knobs and switches
**Glove box light
**Billet aluminum gas pedal
1957 Chevrolet 3200 Pickup
FULL FRAME OFF REBUILD
‘BEST TRUCK’ AWARD WINNER
$49,900
$49,900
Specifications
*Modifications
*Frame
**Original frame
**Modifications
*Drive line
*Interior
**Glove box light
