    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
SC 1968 Ford Bronco U15
jeller68
City: Easley
Price: $ 48500
Selling my 1968 project that is 90% complete and ready for paint.
68 Bronco This bronco is a soiled rust free truck’s as they come . This will be a 3.5 lift with 1” body mounts rolling chassis able to steer, with all running gear, engine, transmission , power steering box, proportioning valve all ready installed with body mounted to the chassis with new body mounts, this bronco will include along with the 68 bronco the title and engine specification Painted black frame ( was sand blasted) 68 body in great solid condition no rust Professionally rebuilt 351 Windsor have all specs and break in oil. Will have all brackets for PS pump, alternator Good Edelbrock valve covers with new bolts / gaskets MDS Distributor / coil New water pump/ gaskets Good spark plugs New oil filter Oil sending unit Painted fan / with aluminum blades / new bolts New harmonica balancer Good alternator New thermostat gasket Aluminum pulleys lower Painted upper pulley New fuel pump/ gasket 4 Barrel aluminum Edelbrock Manifold new bolts 4 Barrel Demon carburetor good running carb Newly painted stock exhaust manifold Good starter New James duff dual exhaust / Cherry Bomb muffler (still in box) NP 435 4 speed transmission great working condition New gear banger Tom’s New clutch and pressure plate/ throw out bearing New clutch fork boot (Tom’s) Professionally Rebuilt Dana 44 with 350 gears New front disk breaks pads / rotor / bearings Good warn premium hubs Dana 20 with J shift setup new Springs and tested New dana 20 transmission mounts (from Tom’s) Both drivelines in good condition Rebuilt 9” med bearing rear end 31 spline with drum breaks / new axles and bearings, new ring and pinion gears 350 4 black MT wheels’ 4 tires 35x12.5 x17 (NEW Micky Thompson Baja ) New toms 3.5 Coil Springs Duffs 11 leaf Springs Duff front shocks towers weld on New polyurethane 1” body mounts (from Tom’s) 4 Shocks Radius arm with new C bushings kit from Tom’s Steering drag link New track bar bushings New power steering shaft kit with nut/washer and bush Power steering box (stock) Steering wheel Power steering pump / brackets/ pulley New drop pitman arm from Tom’s New Power Break booster and master cylinder/ bracket New rear brake shoes/ break cylinders / Spring kit Rear main tank and auxiliary tank / skid plate rear 68 dash with cluster, knobs, glove box door and wiring harness Dash pad . Steering column (newly painted) Windshield frame / glass Electric wiper motor / bracket Two new front fenders (Tom’s) Front and rear fender supports Hood with fiberglass scoop has hinges, hood release Tailgate all complete components great condition Black top good glass Lift gate with good glass Painted smitty built front steel bumper / new bolts Chrome and BOSCH off-road lights Painted Smitty built rear bumper/ new bolts Chrome Grill primed, great condition but was cut at bottom 2 Door all internals and good glass / hinges/door handles/ driver side mirror New san Felipe roll bar WH New shoulder harness belts WH New Front and rear fender flares (black) Tom’s Tail light lens and buckets Headlight buckets/ lamps E-brake mechanism and cable Front disk and rear drum proportioning valve / new bracket Front extended break lines with breather Brake, clutch and gas petal assembly painted Side markers Grill markers Heater squirrel box Vent boxes Added as well Fresh gear oil for Dana 44, dana 20, 9” rear end. New parchment front seats and rear bench (Tom’s) with sliders. New wooden steering wheel (Have original). Shorty headers powder coated ready for installation. Marti report and clear title.
Please call or text me for additional pictures. I don't see how to attach pictures here, sorry. I have plenty
864-940-6505
