This is a donor tub that happens to be on a rolling chassis (kind of, there is no rear Ford axle in it, it went to a buddy that needed a 9” ford for his Bronco. Instead, it has a trailer axle in it to make it easier to roll around) has a U13 VIN. This Bronco has the stock Dana 30 front axle, a seized I-6 motor, and a tub. You can see by the pictures below that it is no looker, but is in surprisingly good shape. Until I garaged it, it had an aftermarket hard top on it that looked hideous. The good thing is that it kept the inside of the tub in good shape. There is also silicone sealant over the windshield hinge that kept most of the moisture out and there isn’t any noticeable rust in that area. I know if I lightly sanded it and added a coat of primer, I could get more for it, but I want whoever buys it to be able to get a good look at it.
More pictures are avaliable at:
http://s135.photobucket.com/albums/q151/wwwdotben/
